I’m looking for a new controller with more power for my Ecooter e2 Max.
I’ve talked with a Ecooter dealer who has pre programmed controller and he claims its an encoder type controller with 150a but won’t tell me the phase amps. Problem is it is not with regenerative braking and I it’s not programmable if you don’t have the equipment which i can’t buy. So I’ve been looking at the fardriver nd7360b and the nd72450b. However I don’t know how many phase amps I should program it. Is there relation between the line current and the phase amps? Ideally I would like as many phase amps as the nd72450b can provide but I’m guessing that would burn the motor and maybe not match the line current of 150amps. So do I just monitor the motor temperature, start low and try little by little to increase the amps?
Btw the stock controller I have now is 64v 65a
