Electro-Schmitt
markcycle said:You might have some interest in the work I'm doing on a high power Hub motor (Motorcycle class Hub motor)
http://endless-sphere.com/forums/viewtopic.php?f=10&t=7718
Mark
Mark-
I've seen your running progress report and will continue to follow your development project. Best of luck to you.
Right now I am limited by a need for a slide-through axle, although while trying to think of a way to accept your fixed axle motor I may have solved my rear wheel alignment problem.
If I could install a pair of tabs to accept a drop-out type installation, I could use a fixed axle motor and also be able to align the wheel. This would add only about an inch or so to my ride height, I could either ignore the difference or offset it with a slightly smaller diameter tire. This solution wouldn't work for everyone but it might for me.
Thanks for weighing in.
