emepror said:
Everyone here realizes that the ESC's we use are all built the exact same way right? an airplane ESC doesn't have a different FET configuration vs a car ESC......plus we extremely overload any ESC unless it's the VESC for the most part. These hobby ESC's are designed for vehicles weighing 10-30 pounds, not longboards and people ranging from 160-250 lb.
Not really.. You would only overload an ESC if your gearing and setup is incorrect causing your ESC to overheat. Granted. Software programming for Airplanes are not the same as Car ESCs which is why it doesn't work. Airplane ESC would work if the software/firmware was correct but it's not which is why you can't use an Airplane ESC. If someone knew how to re-program it with the existing hardware it could be used.
Hobby ESC's CAN be used for RC Car vehicles that weigh 10-30 lbs and they CAN support 160-250 lbs with ease. If your setup doesn't work, it's because your setup is inefficient not because it's a hobby ESC.
Don't be fooled by Tom Foolery "Hobby ESCs are not designed for humans". I have well over 3k miles on Hobby grade ESC's climbing 25% inclines. You just have to make sure your setup/gearing is correct. Psychotiller does as well as many other people on this forum.
Granted.. VESC is a great esc and I support it 100%. Get a VESC
Ben is an awesome dude.
