Electric transmission by serie parallel or delta wye is exactly like playing with gear ratio on a car IEC engine transmission... in both case we play with the Kv of the motor.. but some higher winding are better at low speed than lower winding .
a 5306 bemf reach the battery voltage too soon and stop accelerating sooner... so we just mod it into a 5303 to re gain aceleration and continu pushing current on battery to continu pushing the ebike for crazy speed
That avoid using complicated 150V controlle and 45s battery and BMS assembly ... I think that adding 6 relay in the motor is simpler :wink:
BTW i should be able o produce qty of the PCB for the X5 motor to support and link every relay without confusion for anybody! :wink:
PCB desing v1.0 is done.. ( very basic) but i'll test it very soon. The 80A relay i use have beed tested to up to 140 celsius without any problem
The PCB will fit directly on the center of the motor and the relay can fit perfectly with minor grinding job on the aluminum... Everybody can do that within an hour...
Spliting the winding phase wire strands and identifying them and installing the pcb in the motor and soldering everything cold be done in around 3 hours...
3 little hours for being able to BOOST or... "UP SHIFT GEAR" with your powerfull X5 motor!!! and gain speed! THAT'S WHAT I WANT TO OFFER
I should be able to supply the working PCB soon.
Doc
