Kraeuterbutter
- Joined
- Jun 14, 2007
- Messages
- 197
i have read here somewhere, that somebody was saying, that it will be interesting to see, which of this will be better in longterm use..
and i have found now this test:
http://www.mannertz.de/eflug/bechervg.htm
its german, but i think even when you can not read German you will understand the grafix...
the last grafix shows the cycles..
you can see: the A123-Fepo4 is much better on cycle-life than the emoli, which sees already after only 50cycles a 5% capacity loose..
don´t be shocked by the rest of the graphix...
he unfortunatly killed the emoli-cell after ~50cycles because he discharged it once to 0.4volt accidentily
(a thing, which is not a problem for the A123 Fepo4, tests at rc-groups with over 200cycles discharged to nearly 0Volt without heavy problem have been shown there)
