steveo said:Hey Everyone!
Just wanted to ask, I have intentions of making a 40s bms board using garys bms. Do I have to modify any parts to use this bms & charge at up to 150v?
All I'm aware of is i need to connect the 6 wires to attach the additional channels.
thanks
-steveo
You're crazy man. That's a lot of volts
Yes just the 6 wires for the charge and LVC control bus lines. If you're using the latest version, the voltage regulator should be fine.
