boostjuice said:The camera angle is deceiving. It is actually 26" front & rear.
The long front fork definitely changed the handling. The front end is of course noticeably more raised. Low speed maneuverability is decreased, but the added head angle/rake improves high speed stability, an acceptable price to pay IMHO. Only due the improvement in grip gained from front suspension am I willing to travel at the speeds that the electric drive kit allows. More than ~40kph on the original rigid fork was about as fast as I was confident to take things....but my wrists still ached from the shocks delivered by typical sealed surface corrugations at these sorts of speeds.
Can vouch for that. Even at 4KW+ I didn't have any kind of problem like that with CrazyBike2. (I actually blew the controller before it would do anything of the sort when I deliberately tried to do it, evne pushing down with my feet to try to initiate one).dogman said:At least wheelies would not be such a problem with a long bike.
That depends on your streets. There are places I ride that I wish I had 250mm or better both front and rear. :lol: ESPECIALLY when loaded down!But it might be better to go with a 150mm travel fork than a 250 mm one. 100 mm is plenty for street.
You're absolutely correct - my Bad - although the Mundo frame weight is very substantial - particularly the pre-v4 frames. The Mundo V4 frame was 4.5lb lighter than the v3.3 frame due to removing some luggage rack stays and thinner tubing - that minor frame mod weighed more than the entire Biruni frame.dogman said:Backing up a bit to the frames. 4 pounds vs 47. I doubt the mundo is 47 pounds for just the frame. That's sounding like whole bike weight to me.
Joseph C. said:Thanks for clearing that up. I was pretty sure it was a smaller wheel but I was also wondering how come the real wheel and the stand were still in perfect alignment. It's looks like a great multi-use bike.
dogman said:At least wheelies would not be such a problem with a long bike. As long as you don't get a floaty feeling to the front wheel, and poor steering traction it should ride fine. But it might be better to go with a 150mm travel fork than a 250 mm one. 100 mm is plenty for street.
It's disk brakes, so a 24" front tire is a definite possibility. But if it rides fine, it rides fine.
