cadstarsucks said:If you insist...is International Rectifier a reputable enough source?eP said:So by how many STP FETs parallel we can load the crystalyte controler driver without any impact for rise and fall times ?
Have you any proofs for your original theories ?
Regards
From AN-944, top of page 3:
"The required gate drive current is derived by simply dividing the gate charge, 15 X 10-9, by the required switching time, 100 X
10-9, giving 150 mA. From this calculation, the designer can further arrive at the drive circuit impedance. If the drive circuit
applies 14 volts to the gate, for instance, then a drive impedance of about 50 ohms would be required. Note that throughout the
“flat” part of the switching period (Figure 3), the gate voltage is constant at about 7 volts. The difference between the applied 14
volts and 7 volts is what is available to drive the required current through the drive circuit resistance."
http://www.irf.com/technical-info/appnotes/an-944.pdf
Dan
So what driver current we need for 68ns time and 2 STP parallel load ?
Would you like calculate it ?
What is the right-driver cost ?
