chuyskywalker
Bought a Fiido Q1S from Voro Motors knowing full well the stock scooter is...anemic...for my tastes. But I love building/upgrading PEVs, and these are great little platforms for doing just that.
First, I extracted the controller, battery, brakes, and rear motor. (In hindsight, I really should have just bought a frame, lol).
The plan was to use a Trampa VESC 100/250 I got for a great price to make a real monster out of this thing. I wasn't looking for top speed, but really great take off. This led to a few decisions: 1) single motor. It's common to see these built up with two motors, but that's a ton of extra work and, frankly, unnecessary for my purposes. 2) I wanted the biggest, baddest battery I could fit on it.
I checked the frame over and over, did a ton of 3d modeling for fitment and made up a KILLER 14s20p copper-nickel welded pack with Molicel p26a cells...
...only to find that that cells were spaced further than I thought and I hadn't adequately accounted for padding around the battery nor the case it would go in. It would only fit naked, and even then without leaving room for anything else inside the bag compartment -- which I was definitely going to need.
I ended up having to rebuild it as a 14s14p; same cells, same technique, but a significantly better fit that has space for all the wires, the ewheel adapter, and even my fast charger. Only really ended up hurting range, but still sad news and the perks of having a nice space for the charger isn't to be understated.
Other modifications included widening the wheel for a slightly larger motor, drilling holes for VESC mounting and wire pass through, rewiring the cockpit almost entirely (something like 24 individual wires run from the handle bars into the main compartment), and installing a steering damper. Oh, I also modded some EUC pedals to replace the stock pegs -- much chiller stance.
VESC controllers are great for their core competency, but they lack a lot of options many other ebike/escooter controllers come with -- like horn, lights, blinkers, 3way switches, etc, etc. The "Ewheel ADC adapter V2" from spintend does a stellar job addressing all of those issues and the support from them was fantastic.
To fit the VESC into the frame's seat tube I had to modify it quite a bit. I ended up machining an adapter plate to "lift" it from the tube (the rounded corners of the tube made it not fit), and I replaced all of the power and phase wires with much longer wires that came out at a 90 degree angle. I also made several extension wires for the hall, comms, usb, etc so that everything could be wired into it once it was dropped down the tube and the wires fished out of the hold I drilled. Finally, I made a plate that sits under the seat to hold a "metr" which adds ride logging + GPS & LTE tracking to the vesc.
To attach the rear light, I created a 3d printed adapter plate which uses the seat bolts to attach and then has space for the rear and blinker lights.
The handlebars sport dual-hydraulic brakes, 3way speed power selector; horn switch, light switch, left/right blinker switch, two-way half-twist throttle (acceleration and variable regen braking!), and finally a cell phone mount with a built-in 5v usb port.
After that just a ton of wiring and cleanup. Ultimately the specs come out as...
Battery: 14s14p p26a cells; 52v @ 36.4Ah; 1886 watt hours
Battery/Motor Amps Max: 100/200
wh/mi: ~35
Range: ~54mi
Top Speed: ~43mph
Now; how much did it cost? Well, I spent just a bit over $4,000 -- but I also made some purchasing mistakes and had a bunch of batteries left over. I would say to make this again, with the same setup, and especially if I started from a frame instead, this could be much closer to $3,300. But, that's the cost of hobby-figuring things out. I'm not building for profit, but because it's fun for me.
Overall this is a blast to ride and I'm looking forward to putting a bunch of miles on it.
A picture gallery:
wh/mi: ~35
Range: ~54mi
Top Speed: ~43mph
A picture gallery:
