Thanks mucek. Your web site looks very professional and is easy to get around.
So I have been trying to figure out what is wrong with my BMS for about a week now. Running 24s lifepo4
and have followed the install directions. I am confident I have the BMS wired correctly as I have now went
over that figuring it had to be wrong I don't know how many times. When I do the test below I get the same
results.
Pin 1 to pin 30 gives me 79v , but when I connect the BMS and read the display it gives me 74v and when
I cycle thru the cells 1-12 are correct , but 13-24 not. It's like somewhere it's not reading one cell and it divides
that voltage and displays 13-24 voltages low.
I made sure to push the 12 12 settings for first chip second chip thinking that may be it. It does show the voltage
for all 24 cells it's just 13-24 are not correct. I balanced them with my icharger prior to hooking up the BMS so
they would be in sync.
I put a multimeter on the pins where the bms wires are soldered and got the same measurements as id expect.
Any ideas ? nothing visibly burnt on the board and as far as I am aware I never hooked it up in the wrong order.
Instruction
lease put black pen of multimeter to the PIN1,the ren pen will measure in turn PIN2,PIN3,PIN4.......PIN30.
For example:24S Li-po4,after measurement:
PIN1:0V PIN2:0V PIN3:3.3V PIN4:6.61V PIN5:9.91V PIN6:13.22V.......... PIN14=PIN15=PIN16=PIN17=39.6V .........PIN30:79.34V
