down_under_builder
- Joined
- Aug 30, 2022
- Messages
- 2
Hi,
Been great reading and learning about all you builds. I have a TXT300 that did a gearbox on the weekend so am now looking into combinations to convert. Budget is reasonable and I have time and access to most tools I think I'll need to do the conversion.
To save on buying the wrong bits or those not suitable be great to get some advice. The following are my early thoughts on major components:
Motor: QS 138 V3 - I'm ok with no clutch on this one as I'm a very average rider lol and have kids electric trials bikes and they are plenty zappy enough.
Controller: Fardrive ND72530 - Could go bigger but trying to match to trials application, would like progressive regen braking and have seen conflicting reports if this is doable?
Throttle: Domino or Magura - Want high quality, really controllable low speed have read positive regarding both
Battery: A friend used Molicel 21700 P42A 4200mAh 45A in 16s6p but I'm wondering if 20s5or6p might be better with increased voltage?
Battery BMS: not sure of what to buy, want something that will support regen, quick charging and the required discharge rate to suit the motor.
Suggestions of suppliers also be great
Thanks
Thanks
