Hi,
My first electric conversion. 2012 WR250F with the idea to maintain road rego. Thats still a work in progress. Parts used are;
Motor: QS180
Controller: APT 96800
Battery: 24s17p Molicel p42a ~6.3kWh
BMS: JK-B2A24S
Top speed: 100kph
0-100: 4-5sec
Weight: 136kg (heavy)
Range: 100km city and bush, usually between 65 and 75Wh/km without regen.
Ripped everything off and rewired from scratch.
Motor mount;
Controller mount, regret making it out of aluminium but it hasnt broken yet. it has tabs going into the top motor mount that are not visible in this photo;
The battery was the hardest bit and the most expensive. I made the mistake of engineering too much precision into everything but managed to make it work;
fiberglass vac bagged, didnt get many pics, sorry.
then filled, sanded (eh a bit lazy here but got the sharp bits off) and painted.
Things that went wrong. Had 3 main problems with the controller and motor. One, i needed to replace the encoder wiring with shielded wire because it was cutting the motor out. Along the same lines, I had the white connector on the back of the motor become intermittant after about 2hrs of riding offroad.
If you get this motor put some strain relief on this connector. Neutral cure silicone is good.
Last issue I had with the controller is the crimping job done by the supplier has proved to be poor. I had wires pull free of the crimps with very little force. Fortunately for me, I use the exact same connector for work and have the gear to recrimp properly.
The support from QS motors has been great. So long as your patient they will help you.
Other issues I had was the BMS unit failing after a few hrs. It uses 0603 0.1R resistors as fuses. 2A * 0.1R is 0.2V drop. 0.2V * 2A is 0.4W, way too much for 0603. It is possible that the resistor was a 0.01R, but a bit irrelevent given i had them fail. Anyway, replaced all the "fuses" with 0805, should be good. I also got the CAN version of this BMS, if anyone needs help with it let me know.
Otherwise really happy with the bike. Power is great, battery power peaks at around 31kW and tapers down until top speed. Gear ratio in my case is 11/60. Top speed 100kph. It makes a good dirtbike and a crap road bike. Ran a 16.61s 1/4 mile @ 100kph but Id maxed out before the 330ft
. Going to do something about the shrouds and interested to see what people with more powerful controllers are able to squeeze out of these motors.
Doug
Motor: QS180
BMS: JK-B2A24S
Top speed: 100kph
0-100: 4-5sec
Motor mount;
Doug
