bugboy1641
100 µW
Hi everyone,
Just been looking over Vedders website where he talks about Ratios, Motor KV and Voltage.
http://vedder.se/2014/10/chosing-the-right-bldc-motor-and-battery-setup-for-an-electric-skateboard.
As I'm still pretty new to the whole E-skateboard forum its taken me a while to, I guess, gather all the necessary information.
My design brief is/was:
90mm wheels
8S voltage but maybe switch to 9s. I fly quads that use 3S so was just gonna stick with the 3S but I'm actually planning on an upgrade to my quad to 4s and figured I could just go 4S and swap out between the two and save on batteries.
Top speed of around 40kmh but cruising at 25-30kmh. Auckland has this 10+km long seafront, which is perfect for cruising along plus the odd blast past the joggers.
I had decided on a single HK 245KV 6364 and a 3:1 gearing, 44:14 to be exact(3.14:1) Nothing bought yet.
Using his calculations, I actually should be looking for an 286KV(or equivalent) motor and a 3.66:1 (44:12) gearing to get that magical 8600rpm?
Could someone let me know if my gearing/motor is acceptable or is it better to get it spot on as per Vedders?
Many thanks in advance,
Dan
90mm wheels
Dan
