Hi Guys,
Looking for help with my bike.
When I connect my Lipo batterys and pull the throtle it will stutter at first but then run normally.. untill I let go of the throtle. then no power until I reconnect the batterys on my way home. now when I connect it there is nothing happening only the Frankenrunner light blinking 1, then 3 times.
I have ordered a TTL cable to connect the Frankenrunner but get the no controller connected
(yes the batterys are connected to the controller)
This is my cable, could this be the wrong one?
DELOCK - USB 2.0-cable TTL 3,5 mm 4 Pin (5 V) USB A - chinch 1.8 m
Any other idea how I could get it connected? I did update the drivers.
Then I read there could be a problem with water in the GMac so I opened it and yes seemed there it was a little wet inside.
I let it dry and closed it back up the next day, the first start seemed the stutter was almost gone, but then back to normal.
on reddit someone told me this:
Sounds like a hall sensor issue. The Frankenrunner should be able to be set to sensorless fall-back mode, if you haven't already configured it as such.
My friend who helped me build the bike is not reachable, and I am not realy good with electrics.
If it is a hall Sensor issue, is there a part number for this? hope this is a standard part I can find around here.
Any help would be much appreciated!
