I didn't use a CA. This controller has 30% soldered shunt. I took it from another bike that has a CA, so I know the max current is 25 amps. The tests I did were on a 50 meter 15% (measured) hill. I don't have a fuse because the BMS in the battery limits current.wavezz2k said:D8VEH-
"25 amps using a KU93 9FET controller ..massive torque .. didn't even slow down as i changed up through the gears to fourth" . Could you share more data on your ride, sounds great. Were you using CA or ammeter, or relying on controller rating, do you have a auto fuse inline, did you check temps? How long was test climb, sufficient to get to steady state temperature, did controller or motor seem hot? Thanks for your post.
I took it out for a 15 mile ride yesterday. Unfortunately the battery BMS kept tripping if I held full throttle for more than about 10 seconds, so I couldn't test it properly, but what I can say is that in the low gears it gives the impression of massive torque, but on the open road in higher gears, it doesn't feel so powerful. It was good to get significant acceleration when going downhill at 30mph. Speed on the flat was about 22 to 25 mph, but difficult to be sure because of the BMS cutting the power after 10 secs. The last 5 miles of my ride were continuous uphill, sometimes steep. I could only use half power because of the BMS. The controller was a bit warm when I got home and the motor was more or less cold. I'll try again tomorrow with lipos so that I can use full power all the time.
When the system is new, it takes a few miles for the waxy grease to come out of the chain, so you have to keep adjusting the tension otherwise it's noisy and could jump. I oiled mine after about 10 miles and now it's settled down and is very quiet and no longe needs frequent adjustment. I think it will be important to keep the motor chain properly lubricated.
On the open road the system is fairly quiet. During acceleration from a start, it has slightly more noise than a geared hub motor in similar circumstances. At 15mph and above, the wind noise drowns out the motor noise.
