LightningRods
I picked up my new adjustable primary sheets for the GNG Gen. 1.1 today. The first production run is available now.
In addition to providing better water and grime resistance the new jackshaft makes the entire primary assembly stronger and more rigid. I've added a second through bolt and two steel spacer tubes for even more strength. The final improvement is that I've added an additional 1/2" of length to the adjustment slide to create a better belt angle at the driver pulley and to allow for the use of up to 120 tooth driven pulleys with 18, 19 or 20 tooth drivers.
Coming very soon is my all new belt primary drive. I am changing the belt type to a more performance oriented belt, increasing the width of the belt from 15mm to 25mm and adding more teeth and a proper profile to the driver pulley. I estimate that the new drive will have about 4x the power handling capacity of the original GNG primary.
Many thanks to forum member hillyterrain for loaning me his GNG Gen. 1.1 drive for prototyping.
-Mike
-Mike
