skyungjae said:
It's interesting... just when I think I'm done tinkering with the kit, there's more I want to do with it. As soon as there is a reversible chain drive option (probably never going to happen), I'm probably going to start tinkering with higher voltages as well. Not looking forward to having to re-wire everything with heavier gauge wire though. I should have thought ahead instead of thinking, "12ga will be fine for 20A." :|
Hello!
If you go to higher voltage, no need to up your wire size. The Higher the Voltage, the more pressure or faster the
electrons flow, which generates less heat.
12volt systems to start cars are low voltage (Less Pressure) and higher amperage (Heat), so you need larger wire to
do Work (watts) at lower voltages.
120v at 20amp on #12 gauge is good for 65 feet (2400 watts max)
24v at 20amps on #12 gauge is good for 13 feet (480 watts max)
12v at 20amps on #12 gauge is good for 6.6 feet (240 watts max)
Volting up means your #12gauge wire should be good!
Tommy L sends......
