bee said:Finally bent my crank enough that the chain won't stay on.
Which replacement are you guys ordering from http://cyclone-tw.com/order-chainwheel.htm ?
When I try to buy "Heavy duty DH ISIS 444432 chainwheel freewheel crank set for 68mm and 73mm" the site tries to charge me an extra $117 for shipping which brings the total to $234.
What's the most anyone has tried putting through the stock controller? I'm running mine at 2000w but I wanted to try boosting it to 2500 or 3000w.
Hi,
I managed to bend my crank but only due to falling off when almost stationary failed to clip off SPD pedal.
When I checked the crank I found that only the crank wheel side of the shaft was bent. I removed the bearing cups and swapped them round to put the bend on the non-drive side. The bend on mine is not noticeable at that side. Swapping the cups may get you moving before you get the ISIS kit.
The shipping is excessive from Cyclone and stopped me purchasing from them.
The chainwheel was also bent so I purchased 44-44-32 from Eclipse bikes a distributor for some cyclone parts http://eclipsebikes.com/chainwheel-cranks-p-994.html but they are square taper not ISIS cranks, I did upgrade to ACS Crossfire freewheel. I also purchased their 153mm bottom bracket but did not realise it was so heavily offset; it was no good for the GNG kit. I have since bought a 131mm bottom bracket but haven't tried this yet.
The 44-44-32 is a lot better than the original GNG but I would be tempted to get the 48-48-32 if I was ordering again.
Regards
Dez Ellis
