wavezz2k
Still wondering if anyone's figured out is this small pulley part of the electric motor's armature shaft ?? -
And agreed with earlier post, the 'deep knee' idler tension is to get more teeth on the drive pulley.
; FWIW, my undergraduate is structural mechanics - the chain 'pull' is eccentric to the motor / bike/ mount hardware centerline, so there's definitely a 'torque' on the motor assembly rotating clockwise, when looking down from above, hence Christerl's 'torque strut' makes perfect sense, and assumes to work well.Torque rotation shouldn't be an issue because under load, the assembly is pulling itself "into" the down tube. However, at the power levels some of you are operating, "assembly flex' could become a problem, might require some beefing up.
