Denisesewa said:
I installed the Lyen 12 FET controller, at its present settings the bike is scary, throttle control is almost non exsistant,...
gwhy! said:
turning the Phase current limiting down will help a little but it become a fixed limit and this will reduce the overall torque of the motor so it depends what sort of performance you want from the setup
As mentioned in
the GNG/$400 thread, there are similarilies between your rig and a geared hub motor. A recommended phase:rated current ratio for DDs is around 2.5:1 and that is probably what your out-of-box controller settings reflect. However, MAC/BMC motors perform nicely with a ratio more like 2:1. Here the trick is that rated (battery) current effects the entire rpm range whereas phase (motor) current has only low speed effect. So - a higher rated current will get a broad power improvement, but a lower current ratio (reducing the phase current), will reduce the available low end power.
I have BMCs, not a GNG, (that means this is a guess
) but I'm thinking you might try tinkering the current ratios a bit to marginally assist with your twitchy low end throttle - nothing ill can come of it if the experiment is ineffective.
I'm guessing your controller is set at something like 30A:80A (2.6:1) right now. So you might experiment by first turning down your phase amps to reduce the power at the low end (easier to control) - maybe something more like 30A:75A or so. If this seems too wimpy, you might possibly raise the rated amps to pick up some lost power across the board - having a larger effect at higher rpms where the reduced phase amps are not in play. For instance - you might jack up your rated current to 36A and using the 2:1 ratio, drop your phase current to 36A x 2 = 72A. Just illustrative values but you get the drift... The ratios are just rules of thumb, so you can fiddle a bit e.g. 36A:74A is more than 2:1 but it may give you what you want.
