StouteTiago
New here
Hey All, I have a Grin AAv3 Slow Wind motor with statorade and a Torque Sensing HG freehub, a PhaseRunner controller, a Grin sourced 52v/20A SuperShark Battery and a miniOLED display connected through the SuperHarness. Everything seems spot on with the setup and performance, except I have a weird Chain Slap issue that specifically happens when I stop peddling that I can't seem to get rid of. I have about 200 miles on the system so its not seen many miles. And I'm using a non-clutched Deore M4120 RD shifting a 12-50T 1x10 drivetrain.
I've been fussing with the system for a while in the Phaserunner suite software to try to eliminate the chain slap issue that happens when I stop peddling and at this point I'm fairly certain the issue is Electrical as opposed to Mechanical, meaning there is some ghost current for some reason that continues to turn the motor after i stop pedaling causing the chain to slacken and slap the top of the chainstay, but I've been wrong before so I'm not 100% sure of this. I've thought of trying a clutched RD, like the M5120 that is also compatible with 52T 10spd cassettes, but that would be more like masking the issue rather than fixing it. But it is a last resort option.
The chain slap seems to have no relationship to what assist level I'm in. It also doesn't seem to be related much to bike speed. BUT, it does seems to have a relationship to which gear I'm in. When I'm in the biggest 1/3 of the cogs, the ones closest to the spokes, there's basically no chain slap happening when I stop pedaling. When I'm in the middle range of the cogs, there is a small amount of slap that happens when I stop pedaling. And when I'm in the smallest cogs, the ones on the outside of the cassette, the chain slap is most pronounced. And again, going at speeds where I can use the smallest cogs, but not super fast, or if I'm going as fast as the bike will go, about 32mph, this behavior relative to cog size to be unchanged.
Has anyone experienced anything like this and have either some Phaserunner settings to double check, and maybe adjust. Or thinking about the wheel and freehub, I seem to remember there was one small washer that Grin wanted you to install under an endcap that they shipped in a small ziplock bag at some point, that I'm not 100% sure I in fact did install. Could have forgetting this washer maybe be causing a slight amount of physical binding on the freehub by the endcap? Or is there anything else relating to the the physical setup that I should double check that would be causing the chain to slap more in the small cogs and almost none in the larger cogs?
TIA for any suggestions or solutions for this issue.
