sirensynapse
I have an all axle rear slow wind, phaserunner, ca3, all latest versions, and nothing is working.
Latest firmware, and settings as per GrinEU. GrinCA is not offering any help, and GrinEU is stumped and doesn't seem to want to fix the problem now that he has my money. He said he would have this preprogrammed for me, but didn't touch it, which is evident from the settings it and the controller came with. Thanks, dude.
So can someone who knows their way around this stuff look at my settings and tell me what might be wrong?
The symptoms are:
1 - pedals do nothing. No human power is displayed on CA3, no power is activated when pedaling. No wattage shows on CA3.
2 - the throttle works, but cuts out in 1 second if I push it hard. So it's useless. It's impossible not to push it hard; the thumb trigger has a narrow range and it's very touchy. It cuts out and stays off. Resetting the CA3 brings me back to square one, rinse repeat.
The throttle screen on the CA3 seems to be showing correct function: voltages rise and fall.
The settings here are all from GrinEU directly or ones he told me to adjust after downloading firmware.
I've been fooking with this for three days and I'm royally pissed.
If anyone can help me sort this out, you'll be very appreciated.|
I just edited the bejayzus out of this, so the first 3 comments below are not quite relevant.
The value for regen is set to position, not throttle...fixed that goof, though it was irrelevant.
The symptoms are:
