Alan B
I don't have a Lenovo charger, but my HP chargers run pretty hot. They could use an external fan. It would not work to tape them together or in any way restrict their cooling.
GCinDC said:New bulk chargers. The little black things on the right shown w/ my meanwell/icharger combo for size comparison!
The 'bulk charger' is made of ping 48V 2A charger (61V) and a lenovo 20V 4.5A charger ($9 ebay) in series for 81V+.
I'd been thinking about a couple meanwells, or 4 actually, for home & work, but then I realized that I charge 5s8p @ 10A, so 4hrs for the whole pack, and i rarely use the whole pack. if i charge 20s2p, to charge the same speed, i only need 2.5A @ 80V. i tested it and it seems to work. but i'm rebuilding my pack this weekend, so the full charge will have to wait. And I'll probably do a couple cycles as 5s with the iCharger. But bottom line, I've got a light cheap charging solution to carry aournd! i think i'm going to parallel the AC cords so I don't need two outlets...
If this works well, I may just buy three more of the lenovo chargers to charge at 4.5A!
so the mess, actually just before cleaning up. i would have stayed up late to solder the power leads but my 250W soldering iron started smoking out it's ass.![]()
i spent a fair amount of time thinking how to crimp three 10AWG wires. I sawed the hex end off coax connectors, but the crimp wasn't great (and the soldering iron died) so that decided it.
i know what you're thinking, i got a million bullets to build harnesses.... but something JohninCR said struck home, something about soldering all the connections on his next build. and the truth is that this pack isn't coming apart, if i can help it. the last one stayed in there a year, and i hope this one does too.
i'll use the bullets for the phase wires, etc, but to parallel the power leads, get this, i'm going to use big ass wirenuts. Feel free to convince me otherwise. You've got until tomorrow noon when I'm going to the hardware store!
anyway, here's the hermit crab without its shell, fyi. notice the goo marks on the packs. those illustrate how much the packs have swollen...
side by side to show swelling.
taping up w/ fiber tape this time!
hot-glued the JST-XH's. suckers aren't going anywhere...
more work tomorrow! (and no riding...)
You're right, but the good news is that i've already done this (w/ old case)! (here's the lovely pic once again... )dbaker said:The most common mistake is the leave the balance taps configured in (Series/Parallel) then try to plug the main power lines together in (Parallel/Series) causing vaporization of the main power connectors
I'm dead in the water. Bike is back home in the garage....GCinDC said:No idea now what is wrong but had to get to work. An hour later I'm a sardine getting mushed around in a crowded subway train...![]()
Hehe. The phase wires have been soldered for a week or so. The motor & controller can't be disconnected, except by halls, and I didn't touch anything attached to the controller/bike except the power leads...chroot said:Must be wrong color phase wire <> controller wires... Check all plugs maybe you did misplace or wrong connectors hook up?
GCinDC said:Hehe. The phase wires have been soldered for a week or so. The motor & controller can't be disconnected, except by halls, and I didn't touch anything attached to the controller/bike except the power leads...chroot said:Must be wrong color phase wire <> controller wires... Check all plugs maybe you did misplace or wrong connectors hook up?
Perhaps the solder joint melted, when I took off at 15AMPS! A trail of molten solder and plastic follows me everywhere...
I don't know chroot, I don't know... If the wiring is all good, I'm thinking it's got to be inside the controller.
I've been thinking about getting in there one of these days. My speedo has been out for a couple weeks. Did I mention it? CA works fine, just 0.00 MPH readout all the time... I just wonder if somehow the speed wire fell off inside. If not, I gotta ring up Justin again begging and pleading for a freshie.
Hey Andrey, regen is enabled, but the system was OFF and I couldn't pedal it! So regen wasn't active, unless I'm just powering a generator now...andreym said:it looks like you have throttle regen enabled if it does not allow you to spin the wheel freely
I have had a year of trouble my first CA but the replacement fixed it! Until recently......could be the defective batch from Ebike.ca. See the information below:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=6121&p=91309#p91309
http://endless-sphere.com/forums/viewtopic.php?f=2&t=5959&p=89748#p88965
http://endless-sphere.com/forums/viewtopic.php?f=2&t=21104&start=0&hilit=justin
I hate to say it but I'm going to call blown fets again - that's a classic symptom.GCinDC said:Minute surge? Can't tell. Seemed like it?
Excellent idea! I love it! I'm writing to Santa now for the stocking stuffer...Hyena said:Get a little cheap sensorless 4310 6 or 9 fet controller from Lyen...and you've got a small, light backup solution that you could carry with you at all times.
Hyena said:I hate to say it but I'm going to call blown fets again - that's a classic symptom.
