After three weeks of waiting (Guam...), I have the chainring in hand. My first impression is quite positive, the machine work is crisp and well finished. It is either lightly shot peened or media blasted and the anodizing is even with well saturated color, and the lettering is nicely laser etched into the face. Offset is 18.5mm from the inner mount face to the tooth centerline, and thickness at the mounting flange is 3.3mm. It looks to basically be a mirrored copy of the Lekkie with a couple minor changes. the recess for the mounting bolts is more rounded and the spokes are canted the opposite direction.
Hopefully I will get it mounted up tomorrow.
Edit/update:
Everything mounted up well, it moved the chainline inboard about 3mm from the stock location. I measured offset on the stock ring, it came out at 15.8mm using the same method.
Edit/update:
