Thanks for the tip. I actually like that it goes to sleep, since I only only use it to monitor charging. But, adding maybe 2 hours or so would help in my case, since after a ride, lot of times I’ll want to know the ending charge level after I’ve already been upstairs for a while.On my JBD BMS, Bluetooth is always on. I think it's PITA to have to have to manually turn Bluetooth on after it times out. Googled and found this (not sure if true) "To keep your 100balance (Daly) BMS Bluetooth active, open the app, navigate to parameter settings, and set the "Sleep Time" (or auto-sleep) to a high value, such as 65535 seconds.”
I don’t generally trust ChatGPT unless I’ve asked a question a half dozen different ways, but here’s what it said about active balancing BMS parasitic loads. Im guessing Idle would be similar to what a normal BMS would be drawing when the pack has no load:
| Operating State | Typical Current Draw | Notes |
| Sleep / shipping mode | 5–50 µA | Good designs drop very low |
| Idle (monitoring only) | 0.5–5 mA | MCU + cell monitors active |
| Balancing enabled (no transfer happening) | 2–15 mA | Balancing circuitry powered |
| Active balancing running | 20–200 mA (pack-side equivalent) | Depends strongly on topology |
| Poorly optimized designs | 10–30 mA continuous | Common in cheap BMS boards |
Real-World Examples (Typical)
(Not exact specs — representative engineering values)- Daly active balancer: ~3–8 mA idle
- JK BMS active balancing: ~2–6 mA idle
- Orion BMS (industrial): ~1–3 mA monitoring
- TI reference designs: ~1–4 mA system-level
