spdas
Aloha, I mentioned before I am getting jerky starts and suspect the Halls. Here are the tips from Leaf to trouble-shout and what the results:
Connect all wires,power on.Just disconnect that white big plug with five wires( yellow,blue,green,red,black)
Then measure controller’s hall sensor:
* The voltage of red and black is about 5.0V OK
* The voltage of yellow and black is about 5.0V OK
* The voltage of blue and black is about 5.0V OK
* The voltage of green and black is about 5.0V 0 volts, but when I disconnect from controller, the green controller wire has 5 volts,
so the green hall wire is shorting or the green hall is shorting. But there is no continuety from green wire to ground.
I do not see a "hall board" like I see in other apart motors. Leaf gave me more tips, but it seems the problem is with the green hall wire.
Ideas?
Here are photos of the NON-GEARED motor.
Thanks Francis
Ideas?
Thanks Francis
