Ty for answering I bought it slightly used for $800 so I'm willing to spend a little bit more for better performance but not too much ,I just don't have 5 grand for what I really want. Thank againYou'll have to replace pretty much everything on there (motor, battery, controller, display, wiring, etc, and probably various mechanical parts of the bike) to do what you want, so you should just buy the bike that actually does what you want to start with.
Otherwise you'll be spending more money than it would cost you to do that in the first place, and wasting a lot of time hackng stuff together to get it to fit on there and work.
Ride it until you get $800 of fun out of it while you take your time and plan your dream bike build.Ty for answering I bought it slightly used for $800 so I'm willing to spend a little bit more for better performance but not too much ,I just don't have 5 grand for what I really want. Thank again
You'll need to specify what job you need ti to do for you, under what riding conditions, so that you can find out how much power it takes to do that, how much battery to do it for the time you want, etc.Ty for answering I bought it slightly used for $800 so I'm willing to spend a little bit more for better performance but not too much ,I just don't have 5 grand for what I really want. Thank again
I'm new but not stupid no good reason for the answer hillslayer , can you tell me how to remove the speed limiter?Just use a 72 volt battery and controller and after you melt the stock motor you can decide if it's worth keeping or building something else.
How fast does the wheel spin with no load (full throttle, wheel off the ground)? How fast does it go when on the road?I'm new but not stupid no good reason for the answer hillslayer , can you tell me how to remove the speed limiter?
To clarify for the original poster: If the wheel spins significantly faster in the air than it does on the road in easy conditions, then your speed limitation is the result of limited power. If the top speed is the same either way, then it's electronically limited by the controller to comply with regulations.How fast does the wheel spin with no load (full throttle, wheel off the ground)? How fast does it go when on the road?
Note that even adding power, the motor will not spin faster than the no load speed, which is the limit based on the motor’s Kv rating and the voltage applied at full throttle.To clarify for the original poster: If the wheel spins significantly faster in the air than it does on the road in easy conditions, then your speed limitation is the result of limited power.
32 mph off the ground 24 while on the road and l am 160lbsTo clarify for the original poster: If the wheel spins significantly faster in the air than it does on the road in easy conditions, then your speed limitation is the result of limited power. If the top speed is the same either way, then it's electronically limited by the controller to comply with regulations.
In the case of the former, you'll need more power to go faster-- see amberwolf's comments about that. If it's the latter, you can go (a little) faster by replacing the controller and display with unrestricted versions.
So change the controller32 mph off the ground 24 while on the road and l am 160lbs
Thank you for your input32 mph off the ground 24 while on the road and l am 160lbs
Well, either a peppier battery or a zestier controller, probably combined (because the battery you have is likely maxed out doing the job it has now), would give you both higher top speed and better acceleration and climbing.32 mph off the ground 24 while on the road and l am 160lbs
At 24mph, the wind resistance (load) is fairly small, so adding more power may not yield much, if any, speed increase. Going up in voltage will increase speed, all else being equal.So change the controller
Thank you for taking to comment.I appreciate your advice32 mph off the ground 24 while on the road and l am 160lbs
