Tongsheng TSD Z8 didn't fit my carbon frame. Two brushed MY1018 motors fried in 30 miles total. Back to square one. Here is the link:
https://www.amazon.ca/brushless-Square-Diameter-Sensor-48V-400W/dp/B0CSJV496Y?th=1
The one I got was only $108
This looks great because:
1. It's only 140mm across besides the output shaft, so add another 30 mm or so for the shaft to 170 total. That can just barely fit between a standard Hollowtech crankset. If needed, a Superboost crankset is 181mm wide, or an extended 141mm square-tapered bottom bracket. I have both in the garage (I actually sold the Superboost but can buy again if needed). The 300W version is 150mm wide total including the output shaft, a significantly more amount of wiggle room between the pedals if you need it. And I may need the 300W version instead, we'll see. Free 30 day return for this unlike the damn Tongsheng.
2. It has four M5 bolt holes on each side.
3. I luckily have 2 1/2 sets of mounting plates: GNG 450W MY1018 brushed motor plates, Yalu 450W 48V brushless mounting plates, one used Cyclone mounting plate to mix and match. This motor is only 2.5 x 2.5 inches for height/width. The GNG drive side has about 2.7 inches for the sprocket part of the motor. Can shim/mending plate the empty space for a tight fit. Probably can only use one bolt on each side and other bolts can be mated to mending plates or even zip ties since I will not be using more than 800W peak.
4. The motor weighs less than 4.5 lbs, peak torque is around 75 nM with a 2.5x 1st phase reduction w/16T freewheel and 40T chainwheel. Not BSSHD level but good enough.
5. Output shaft is 14mm, beveled on one side for a keyed 15mm freewheel sprocket adapter. Another extremely important variable for a DIY mid-drive dual chain drive: the shaft width and if it's keyed or not.
6. It's brushless. That is priceless. I can't stand brushed motors on bikes, especially up hills. The internal heat increase on brushed can be faster than you can even react to.
I'll install this weekend. BTW Microsoft's Copilot was much more helpful than Alexa for choosing this motor. Alexa kept sending me to the wrong motors over and over again. Copilot listened to what I needed. The only complaint I have is that Copilot insists that I can use a larger motor than what can fit between my pedals. They say I can install a 230+ mm motor in front or on the side of the bottom bracket. Ummm...no. That can't work. The motor must be 100% transverse to the frame and parallel to the bottom bracket so that first it can bolt on to the bb mounts, and second the sprocket chain is parallel (in line) with the chainwheel. The only way you can mount something longer than the pedal spacing is way up in the triangle or far up the downtube. The pedal cranks are 7 inches long and the pedals themselves have about 1.5-2.0 inches on each side so that's around 9 inches away from the bottom bracket to clear. That is a long way folks.
I'll let you know how it goes with 400W and 170mm wide.
DC 48V brushless DC Motor 60mm Square 14mm Shaft Diameter 400W brushless Motor with Hall Sensor (48V-400W 14mm Shaft Diameter Motor)
