Audisport09
https://www.youtube.com/watch?v=TQ9BlSu_9VM
Hello, some help with my ebike would be much appreciated. I’ve got an intermittent t problem where after less than a mile of easy/hard riding the controller stops the throttle from working and starts make a clicking/ tapping noise instead. The regen, continues to work, no fault codes. I’m using QS205 and BAC8000. I’ve tested the motor phase wires and no shorts to motor axle. I’ve also tested the controller phases to positive and negative no shorts founds. Checked the throttle and it working fine. It can take anywhere from a few minutes to hours before it starts running normally again. I cannot replicate the problem from no load operation. It only happens when out riding. I’m suspecting motor, maybe burnt/shorted/ demagnetized? I don’t have another motor to test. I’ve got another controller but I’m scared that I might damage it too if the motor is at fault. That is the last resort ideally. Is there anything else I could do or test?
