seranikas said:
Which specific motor are you looking at?
this one to was a one I noticed but I would probably need to be guided on the exact model required.
https://www.qsmotor.com/product/16inch-8000w-scooter-motor/
Once yo'ure sure how much power you need the motor to handle, tell QSmotor what your tire/wheel size will need to be, and what maximum speed it has to go at the battery voltage you decide on, and they can get you the right rim built onto it and the right winding for that speed at that voltage.
Before you can tell them anything, though, you need to decide the actual max speed you want, and then determine the actual power it will take to to maintain that speed under the worst case conditions you will ever come across.
You'll also need to figure out what battery voltage you want to do it at; higher voltages make faster speeds easier, and decrease current needed for any particular wattage (power), but narrow controller selection and increase personal shock hazard.
For controller options to run the motor, you can talk to QSmotor to find out what will match your needs.
The wheel I have on there now are the stock 15 inch rims but since it's shaft driven Had already notices that I could possibly use the old shaft housing to mount the motor with minor modification and welding for support since the left side rear axel connection point is a bolt tightened clamp, and the shaft housing is removable with four nuts which by theory could make the rear tire hub removing process to be loosen bolts/nuts and slide to the side rather than back. and the removing the original shaft may create a decent housing for the motor cables.
That makes sense.
only question on these as unlike many other bikes the brake disk is on the left and the driveshaft is on the right, reverse to other bikes I see on the road, these motors can be easily hooked to run reverse by swapping the Positive and negative lines to the controller? or perhaps add a reverse switch to make for backing up from parking spots or awkward turns?
Many controllers have a reverse function, either as a wire pair (for a switch) or a function in the setup software. If not, it is relatively simple to just wire the phases and halls so that the motor spins whichever direction you need it to, (if the controller has no auto-learn/etc functions).
There arent' any positive and negative motor wires for brushless motors (the type you will almost certainly use), and you can't swap the battery to controller positive/negative wires or you just turn the controller into smoke.
apologies for the minor monologues my autistic ass tends to just ramble and I leave notes where ever they seem on topic to find later.
I spend quite a while on each post, typically, writing things as they come to mind and then editing them until I think they will make sense to someone else. If I don't, it doesn't usually get across what I intended. Either way, I tend to be fairly wordy to ensure all the information that is needed is present...what people do with that, or whether they even read it, I can't control.
The goldwing is Shaft driven not chain so here are a lot of parts that would be removed. the engine weighs around 230LBS on it's own, the shaft that drives the rear tire on it is a solid piece of metal so might be heavy as heck as well. so possibly would drop the weight of the bike a good 300lbs or more after removing all the old engine and system parts. Currently had it weighting around ~700lbs after removing and replacing some parts and taking it to my dad's factory to weigh out of curiosity. Apologies if the I used the wrong terminology.
I don't know most of the ICE motorcycle terminology.
I would remove any part that was part of the ICE engine and drive system that you don't physically require to hold the bike together or make it operate normally as an EV. It will simplify the bike and build, and make it lighter.
Note that quite a few bikes use the engine as a "stressed member" of the frame, so once that is removed, you may need to add framework around the battery once designed and built, to give the bike the same frame strength it was built with originally (or better).
on this topic, since stripping the Original Airshocks pump from the top fairings They left an empty cavity, possibility of having a dedicated AUX battery with an Isolator mounted in the fairings to isolate power for the lights/stereo/gauges/Auxilary-items from the fairings itself was a throught, that may or may not be as feasible. connecting the AUX battery straight to the charger to keep it powered and not drawing power from the Motor batteries. Thoughts?
You can certainly do this. I use a separate battery on my SB Cruiser trike for the "12v" stuff, partly because a DC-DC that will do what I want cost more than I had avaiable, but I already had batteries that would do it.
Partly because then even if somethign goes completely wrong with the motor (traction) battery system, I still have lights, etc.
The disadvantage is that it means you must have a battery that can completely supply all the power the lights/etc need, for as long as you need them, *and* you must have a separate charger just for this battery.
If you want a drop-in solution, you can use a lithium-based automotive / motorcycle "12v" battery, and just get a charger for that that will run off the same voltage the traction battery charger is going to use from the charging stations and wherever else you will plug in.
If you build a battery for lighting/etc., you will probably use a different kind of cell than that used for the traction pack, that has the right voltage range for the "12v" system. We'll get to that later, when you are doing battery stuff.
also had removed all candecent bulbs long ago, replaced them all with LED because of preference.
Are you including the headlight? If not, you can change that, but I would use a completely new LED headlight unit; I have never found an LED replacement for standard headlight bulbs that actually works inside the incandescent housings to give the correct light distribution and "horizon cutoff" lines, etc.
I am not sure where you live,
It's in my profile (but that particular info should show on your screen next to each post, like my signature does below each one).
but California had started adding these chargers in major areas first and started spreading them out to smaller communities later, they tend to be around malls, industrial parks, recreation areas, and major shopping centers. But I'll verify the charge rate of these. Also they do have hard readers that charge per watt so that may be a burden.
Well, everything has a cost.
If you simply look at the website that should be listed on each charge station "brand", it should show you what is required to use it, and what features it supports. Once you know that, then you can get the appropriate connector or adapter for your charging system (once you know what charging system you will have on the bike, which comes after figuring out the power needs (motor, controller) and battery.
Tesla is like Apple, their chargers will only work if it reads the car's serial number, the chargers for theirs have a data cable that would block all other cars from using their chargers, I'm an IT worker but not a hacker to create a bypass for that system. I had to assist in running maintenance on these once. Real asshat move Tesla.
SOme of the websites that discuss charging stations say that only the Supercharger stations are Tesla-car-only, but that the regular Tesla stations will work as long as you have a Tesla-to-J1772 adapter. I don't know enough about that to know how it works (or if it does), but perhaps that's something you can verify.
Only other item I can think of, though slow as molasses, is making a motorcycle cover have a foldable solar panel canopy to store on the bike. I like to venture to the mountains and just leave my bike or car in the lot all day while I enjoy myself, so possibly not gonna charge 100% or even 50% in 8 hours of sun (5 direct sun a day) but it would be enough to possibly ride back from my campsite or trail to a local charger or pluggable area and get some dinner.
You wont' get very much power a day, nowhere near a significant charge, from a canopy you could carry on the bike.
1 square meter of 100% efficient panel (which doesn't exist) would get you about 750-1000w per hour at noon on a perfectly sunny day with no dust, clouds, pollution, etc. blocking any sun, near the equator. It's less (much less) in realworld conditions, and unless you have sun-tracking panels, or manually keep tilting htem to keep them facing the sun, you'll get even less when they're not perpendicular to the sun.
I have four fairly crappy old "12v-15v" panels (three like the ones they sell at harbor freight in the 150w kits, one smaller and differently shaped but close to the same area), and they are large and heavy and fragile, and don't make much power even here in the desert in summer at noon. They cover about half of the top of my SB Cruiser trike; some pics over here:
https://endless-sphere.com/forums/viewtopic.php?f=41&t=106119&p=1556809#p1556809
To carry something useful that would make an actual canopy that you can setup over /around your bike, you would probably need at least two of the size panels they mount on house roofs. Let's say you use two "300w" panels (which you'll probably get 250w or less out of), with a lightweight aluminum frame (like some old army cots use; this is what I made the SB Cruiser's non-solar trike-mounted canopy from). They're probably going to be around 5' x 3' or so, so if you go with long-way mounting, that's 10' x 3' for a canopy. I don't know how thick, but let's go with 3" to leave space for any padding between panels you may need to protect them, so two will be 6" thick that way. They'll probably weigh about 40lbs each, so about 80lbs for panels, and let's say 5-10lbs more for the frame. You'll probably get about 500w out of these two, perhaps less.
If you need faster charging, and/or a bigger canopy, you'll need more panels, which will weigh more and be physically larger to carry on the bike. At 500w charging per hour, if you use 100wh/mile to ride you could get up to 5 miles range per hour of charge. I suspect you'll get less charge than that; depend on whole system efficiency (MPPT, etc).
Imagine carrying two or more large heavy fragile folding tables on your bike.... My guess is you would want a trailer for them instead. A friend of mine used to use a Kawasaki Voyager (dunno what year) which is similar size to a Goldwing to pull one of those harbor freight trailers that have a clamshell cargo carrier on them, for long interstate trips. HF has carried a number of other trailers that would work even better; you could certainly make something yourself, or modify one of those, to carry the panels and even make a frame that unfolds from the trailer itself to deploy it all in one easy setup, without having to assemble a frame, mount panels, etc.
You'll also need an MPPT to get the best efficiency from them; if this goes directly to your traction battery's charge port for best efficiency, the MPPT will need to output the correct voltage and current to charge it. I don't know what voltages MPPTs are available in, but you can look them up when you get that far. If you instead use the MPPT to run an inverter to run your charger, you then lose a whole lot of power in the inverter and charger.
There are quite a few solar discussions here on ES if you would like to read around, including some ebikes that are powered by this (like in the SunTrip threads) to give you some real world data. THis site
https://us.sunpower.com/how-many-solar-panels-do-you-need-panel-size-and-output-factors
is also useful.
