Nope. In the example, only the battery voltage is increased.Did the current also increase when you increased the voltage?
Not sure what you mean, but I see a real world torque advantage over the entire torque curve with System B, when only the battery input voltage to the system was increased. Are you saying that torque advantage is not there?If the current had not reached the max set limit, then the current can increase just by increasing the voltage
Doesn't matter. Neither was changed between system A and B.To be specific, are we talking battery or phase current?
Uh, that's because like any controller it has a rating for battery and phase amps. Are you familiar with the simulator?@E-HP, your example controller has dual amp values
The example above:How do I get the simulator results here?
Yes. You're phase current is so limited, you are operating on the flat plateau section of the torque curve. Anywhere where you're bumping up against the phase limit will produce the same torque. Look at the power in your example. Same power, same torque, exactly as I stated.EHP, can you link to my simulation?
The controller phase current is exactly the same in the System A and B example. Only the voltage has change. Explain the torque increase.Hence stancecoke point, motor torque IS controlled by phase current
I said the controller phase current. You can buy a controller or a battery. Controller didn't change. Battery did. Again, between the two systems, only the battery voltage changed, and now there's more torque. Why didn't it stay the same?30,1 = 51.1?! View attachment 372415
Folks talk about torque in terms of maximum torque. But torque changes over the operating range, so when people say they need more torque, it's rarely the off the line maximum torque (that drops like a rock as speed increases), but somewhere in the range that they ride their bikes in. Raising current will increase torque on the lower end, but the still drops to the same point when the top speed is achieved (no more useable torque). Increasing voltage shifts the torque curve to higher speeds, so even though the curve is still descending, at the same speeds, torque will be much greater. Out on the road, that's what counts more, for safety.Think he need a throttle! That is what is used for short bursts.
Old memories coming back of discussions of torque vs power that went on for years and years. "amps vs volts"
Yes, I responded as well. You proved my pointEHP, did you link to MY simulation? Two diffreent battery voltage, same wheel torque and SPEED.
Again, this is not because of the voltage, but because of the current limitations of the controller and doesn't help the thread opener. Only in zone C of this chart, a higher voltage helps. In zone A the controller cuts the motor current, in zone B the controller cuts the battery current.so even though the curve is still descending, at the same speeds, torque will be much greater
Got it years ago, own the slowest Leafmotor on this site or does anyone have slower than a 7T. Run it at 72V mid range torque.Folks talk about torque in terms of maximum torque. But torque changes over the operating range, so when people say they need more torque, it's rarely the off the line maximum torque (that drops like a rock as speed increases), but somewhere in the range that they ride their bikes in. Raising current will increase torque on the lower end, but the still drops to the same point when the top speed is achieved (no more useable torque). Increasing voltage shifts the torque curve to higher speeds, so even though the curve is still descending, at the same speeds, torque will be much greater. Out on the road, that's what counts more, for safety.
For a hub motor, you want the torque where the motor is still spinning efficiently. The low RPM torque is less useable since the motor will cook itself, so you want more torque at the OP's climbing speed.
After testing voltage levels between 14s and 22s, my conclusion is if you want good acceleration between 20-30, for example, you need to go up in voltage and build at least a 40mph bike. No amount of current increases torque at higher speeds in order to produce any meaningful acceleration unless you shift the drop off of the torque curve to higher speeds.Got it years ago, own the slowest Leafmotor on this site or does anyone have slower than a 7T. Run it at 72V mid range torque.
