Firebird
New here
Hi guys,
A little history.
I am new to e-bikes and am wanting to convert my Haro Sonix which I love to ride, however due to health issues I need the ability to be able to either Ghost Pedal or use a throttle to get me home if my illness flares up..
After doing lots of research and reading I have hit a brick wall. The reason is the the Haro has the crank on the rear suspension arm and the connection to the down tube means the the spindle nuts are recessed in to these connectors. The attached photos show it much better than I can explain.
Initially I was looking at a mid mount motor however after seeing how they are mounted I believe that they would not work, I even considered a CYC Gen 4, but again I eliminated it due to the rear arm mounts.
That left me with Hub motors. They would work however then I realised that there was on issue trying to install a pedal sensor. Again the issues was the rear arm mounts.
Any advise on the above would be greatly appreciated.
I think I might have found a solution. I realise that this is a Torque Sensor, I am prefer that, however as I am a newbie I would like input from people that hopefully know allot more than I do.
As I need to climb a hill in order to get back home I am looking at a 48v 750-1000w geared motor. Have looked at 2000-3000 direct drive and they may be an option however I do have to be a little careful as in Aust the max size legal motor 250w. I will be riding it on the street however I live in a small community that police seldom visit.
As I have said any advice would be very much appreciated.
A little history.
