A
Anonymous
Guest
slayer said:Hi Mikereidis,
i am from aylmer too in deschenes exactly, near the river,
i am curious to know a little more about the load test you did with an old fashion 1500 watts 110 volts ac heater
1 did you plug it in directly or you used an inverter please tell me more about that ...cause i was thinking for winter maybe i will use a electric heater to heat the car faster...
and is the test results discharging with the trimmer or with that ac heater ( at very low setting i would assume )
ZapPat said:I would really like it if someone could do some load tests to determine voltage sag under different current draws on these batts. This would give us a good idea of the internal DC resistance of these packs so we can compare their quality to other batteries. See my suggestions to do so here:
ZapPat said:mikereidis,
- How did you calculate total Watts-hours from your voltage-time graph? Was it by calculating amps at each V point you took; then using both the Volts and amps graph over time to add up used Watt-hours in total?
http://endless-sphere.com/forums/viewtopic.php?f=14&t=4908&start=60#p81636
ZapPat said:If you do this, make sure the voltage readings are done right at the pack's output (as I'm quite sure you know, Ns&Vs - this is mostly for others that might want to do this too to add to our knowledge base).
Thanks for all your posts, man! I just wish these packs were on special sometimes, but somehow I don't think this will happen.![]()
Pat
