Chalo
100 TW
Time for you to ditch the magical thinking and admit that the function of dampers is to throw kinetic energy away.
I believe you misspelled logical :wink:Chalo said:Time for you to ditch the magical thinking
You forgot the spring, genius.Chalo said:Consider this: With a low frequency ripple in pavement, an unsuspended bike will treat the surface as a series of small hills, decelerating on the uphill side and regaining the lost speed on the downhill side of each undulation. But suspension compresses on the uphill side, converting kinetic energy into heat in the dampers, then extends on the downhill side, again converting kinetic energy into heat in the rebound dampers, and then as the vehicle returns to its normal amount of sag, it will burn off a little more energy yet.
full-throttle said:Now the difference is: the unsuspended bike and rider has to follow the contour of each of these 'hills' while in the case with suspension only the unsprung mass has to follow. The rider and most of the bike travels straight.
Motion in a straight line requires less energy.
Chalo said:When surfaces are good and smooth, mechanical suspension throws away a lot of energy that could be used to propel the bike, or to keep it rolling
I'm asking for the 3rd and last time - PROVE ITChalo said:On a "good and smooth" surface it wastes a lot of pedal work. On an undulating surface it wastes a lot of forward velocity and pedal work
Are you talking about rear suspension? Is that the bike with the extended swingarm?John in CR said:I'm no cyclist, but I can definitely feel a suspended pedal bike suck up leg power requiring more effort than a bike with no suspension, same tires and road.
amberwolf said:Simple test that should determine the answer to the suspension energy question:.....
Another example of correlation doesn't imply causation. I could say the average speed of athletes increased since the introduction of suspension, so suspension must be good then.melodious said:Chalo made a very good point a few comments back. "Racing road bikes have regulated minimum weights that would allow them to have suspension and still weigh the minimum. None-- as in zero-- of them have any mechanical suspension at all. It's not for lack of budget, or because guys racing 120 miles a day at full tilt couldn't use some extra comfort. Manufacturer sponsors would love it, because it would allow them to sell a bunch of really expensive toys to eager tools. Suspension road racing bikes don't exist because they would lose. And that's at e-bike speeds or more. "
Well since Chalo can't support his own claim I can disprove it instead:Chalo said:When surfaces are good and smooth, mechanical suspension throws away a lot of energy that could be used to propel the bike, or to keep it rolling
That's because a large proportion of energy loss in a tyre is soundChalo said:Knobby tires don't get noticeably hot either
full-throttle said:That's because a large proportion of energy loss in a tyre is soundChalo said:Knobby tires don't get noticeably hot either
Chalo said:full-throttle said:That's because a large proportion of energy loss in a tyre is soundChalo said:Knobby tires don't get noticeably hot either
for the lazyRolling friction generates sound (vibrational) energy, as mechanical energy is converted to this form of energy due to the friction. One of the most common examples of rolling friction is the movement of motor vehicle tires on a roadway, a process which generates sound as a by-product. The sound generated by automobile and truck tires as they roll (especially noticeable at highway speeds) is mostly due to the percussion of the tire treads, and compression (and subsequent decompression) of air temporarily captured within the treads.
full-throttle said:for the lazyRolling friction generates sound (vibrational) energy, as mechanical energy is converted to this form of energy due to the friction. One of the most common examples of rolling friction is the movement of motor vehicle tires on a roadway, a process which generates sound as a by-product. [...]
John in CR said:Interesting about the road race bikes. I thought they all had the lightest construction bikes possible...part of the science of the sport.
