dirty_d
the best thing you could do to get best efficiency and at the same time have the best acceleration would be to use a computer controlled CVT, from a stop it would start from the lowest gear ratio and gradually shift higher as you speed up to keep the motor rpm at the peak power output to maximize acceleration, once you are up to cruising speed it would shift lower to keep the motor at the peak efficiency RPM, that would be a balance of acceleration and efficiency, if you just care about efficiency it could just keep the motor running at peak efficiency RPM all of the time. of course thats probably too complex and expensive for an electric bike but it would be cool.
