Alan B
john61ct said:OK no time now, will parse later see if specific answers are there to see if my understanding is better.
Well when choosing and sourcing the components. . .Alan B said:You have to model your actual data to get specific useful predictions. Generalizations don't get you there, even if they are all correct for some situations.
> Or mid drives with variable gearing...
I thought just not available big enough to push 400-500lbs up long steep mountain climbs
And yes I know, figure out the simulator
It is certainly available. It is called motorcycle (or scooter) parts.
The 3000 watt hubmotors weren't made for bicycles. They have been adapted to them. But trying to push a lot of weight up a steep grade takes power, and the motor needs to have low enough losses to handle it. Or it takes gearing. If you don't care about speed but want a lot of torque and mid drive parts are not strong enough then use a left hand chain for the motor.
Some mid drives like the BBSHD will handle enough power to handle more weight at low speed. Just be prepared to do more than average maintenance.
