I've got this cheap combo I'm trying to hook up Brushless Motor Controller, Waterproof 24V-48V Motor Controller, LCD Display Electric Bike Scooter Brushless Controller Kit(36V/48V 350W) : Amazon.ca: Sports & Outdoors
The problem is I can't get the throttle to work. Even setting the display to Throttle only the wheel will not turn
The only way to get the wheel to spin is to connect intelligent wires and increase the PAS 1, then it will spin without turning (free wheeling) the wheel, I unplug and plug it back in and the wheel will start turning. It stays at the same speed in PAS 1-2-3-4-5 and turns off at 0.
I've tested the throttle previously and it was working fine, proper voltages to the proper wires.
I don't have the sensor wires connected now. They weren't helping and now one of the wires is broke.
The last bit of info is I don't have a chain on the bike. I don't think this was a problem when I had it going last Summer.
Anyways, I started early this morning because it was supposed to be hot and this snafu has taken me to the point where the sun is overhead and there's no shade ad it's like 120F on the patio.
I can provide pictures and videos but I suspect this is one you've either seen or you haven't.
