Matador
- Joined
- Jun 29, 2016
- Messages
- 1,045
Ebikes4Real, I just want to verify some info about the SMD type Shunt resistor before I pull the trigger on buying these components :
1 - The shunt resistors are of the 2512 size (6.35 x 3.05 mm ; 0.25" x 0.12") <--- Verified and edited this 2017-06-23
2 - The MOSFETs, I found these IRFB3077 mosfets for 5.12$ (CAD) for https://www.digikey.ca/products/en?keywords=IRFB3077PBF
Is that the good component ??
I might try the shunt mod without changing the mosfets a first, buy I will get the new FETs on the same order though. Unless you can suggest some even better ones
Fechter, I cant believe 30Amps are going through such tiny SMD components !!! This ???
