NeilP
1 GW
Any one have a circuit that will flash turn signals on a 48volt e-scooter.
It was 36 volt, but had battery upgrade to 48-50 volts, and the old flasher unit let its smoke out.
Front bulbs are 40volt 3 W and rear bulbs are 12volt 5w with a big 2 inch 47ohm wire wound dropper resistor. Cant find suitable rear bulb style in correct voltage, hence the 12volt rears.
Original flasher is two wire unit consisting of :
3 resistors
2 electrolitic caps
Diode
Buzzer
Small 3 pin un marked signal transistor
Larger (taller) 3 pin 'transistor' ...? Darlington pair package possibly if my reading of markings is anything to go by. D1978 or similar
Not reversed the board to schematic yet.
Just wondered if anyone had a suitable ciccuit ready to go to save me the hassle.
3 resistors
2 electrolitic caps
Diode
Buzzer
