I think this thread should be made a sticky with only hard facts, then locked for moderators only to change. I'd link it a lot
I'd like some things added to the first post:
If you have troubles with your controller, motor, battery, bms:
-Describe the problem you have.
-Answer this question: has it ever worked before.
Answer:
-if it has worked but stopped, describe what happened between now and the last time it worked.
Answer:
-Describe your parts completely with name, links to manufacturer or seller. If you don't know, post detailed pics of parts and any markings on parts.
Answer:
-If a motor is running poorly, post a youtube video of it running poorly. With sound.
Answer:
-If your controller doesn't work, post pictures of the program setting screens (if you can)
Answer:
-If your speed is not as expected, post complete system description with battery, bms, controller and motor specs (including kV or measured motor noload speed achieved at what battery voltage), gearing front&rear and tyre dimension.
Answer:
It would be so nice to get everything needed to help people efficiently
