yoyoman
My used commuter booster is set up, but it's not working reliably. I’ve adjusted it so that the motor is 1mm from the wheel. The motor does engage the wheel, but it won’t stay engaged.
I’m looking for advice to improving my situation.
1) I have the CB clamped on a dowel screwed into the kickstand plate. Would there be any benefit to lowering the motor 1cm on the dowel?
2) Would a smaller, lighter motor help?
3) The prior owner’s grip tape has come off, so now I’m running with just the can. How do I clean off the adhesive gunk? I doubt it’s helping.
4) Would grip tape, ie low grit sandpaper help here?
