aaronski
Hi guys, I've done over a year of LiMn testing on bosch fatpacks. and now, not one pack works at all. I know DrBass says their bulletproof, and he's mostly right, but even they have their limits.
for about a year I rode various configurations of 6 fatpacks.
1. the sag hammer- one pack, 72v, 2.2ah probably 50 cycles like this. pulling 50-60 amps, or 25-30c out of 5c rated cells, I managed to sag them from 80v hot to 55v under load. it got worse as the SoC dropped. after this, they still had no appreciable ah loss. I got 2.2 ah from this config.
2. gotta... get...home..... 10 cycles of 100% DOD, I pulled the cells down to 20v on a 72v pack. at full throttle I'd only get 100 watts.
3. Oops. Left batts on controller over weekend, come home to 0v. also, repeatedly left packs lying around dead.
4. 72v,6.6ah 60 amps max- about 100 charges like this. worked like a charm. was still pulling 10c out of 5c packs, but the sag was about 10v. untill....
5. Finally killed them. - wore through the tape harness I made for one half of the pack, and dead shorted various cells to the bike frame. black goo seeped out of various cells. took about 2 weeks to realize this. meanwhile, I'm charging the pack to 85v hot, and likely only on 36v of cells, so doubling their voltage?? seemed saggy to, as I was dropping it from 84v to around 40 at first touch of the throttle.
results:
out of 6 fatpacks, I have 2 that still work, marginally, around 2.0 ah from them at 5c, but sag to 28v pretty quickly. the other 4 packs are not recognized by the charger at all.I've tried just various cells, no love. one charger says no connection. the lead acid charger doesn't respond to plugging them in.
results:
