gedong
Can anyone help me on how to switch off BMS ? ( zero draining power for long term storage) ?
at the moment, i'm gathering information about building battery pack, and i 'm a little bit confused about which BMS should fit my needs..
the battery case have 2 switches, button and keylock.. i guess the keylock is the switch for BMS on/off , and the LED button is for BMS current circuitry.
it also has +5V USB output for charging, this will required separate DC-DC module LM2596HVS to supply the USB module.
here's the connection diagram and inside battery case.
and, here's the assembled battery pack, surprise how small the BMS are. the specs are Max 20A discharge ?
i asked this picture from some seller in chinese aliexp***
if i want above switch to functions , do i need special BMS ? or any BMS maybe can be modified ?
here's similar BMS which have switch off
this BMS from elifebike supposed to have on / off switch, but i don't see any connector..
http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2014-3C-MR54.027KF
and, anyone have experience with elifebike ? i live in Indonesia, so it's kind of difficult to find reliable resources with decent price..
sorry for my bad english, and thanks in advance.
