HS3540 - How do I remove the cover?
kev82
100 µW
I have a HS3540 that's got the infamous wire issue, and I managed to disassemble the motor:
Now the problem is: How do I remove the side cover so I can change out the phase wires? (It looks like the hall wires are intact, just the phase wires that are stripped)
Also, is it likely that this issue damaged anything in my build? For example the controller or hall sensors?
Here's what the damaged wires look like:
I couldn't find this anywhere on the forum so I'm bumping this... Do I remove something so the cover becomes loose or what?
The cover just slides off. Its just hanging up on the phase wires. Its a bit of a challenge to get the first bit started but keep wiggling it and applying pressure to the axle and it will slide off.
