markz
100 TW
Should be considered dangerous driving.
Actually, these probably aren't facts at all. First of all, they're not independent numbers, they're overlapping numbers. But more importantly, you're not quoting the National Safety Council. You're quoting a Newsweek article and they in turn are likely misquoting the NSC research. We don't know exactly because the report your numbers are based on is not a free publication. However the NSC does have a statistical highlight report and in that report they are clear to say that alcohol, speeding and distracted driving are factors in fatal accidents, not causes. And really all that means is that the driver was traveling over the completely arbitrary speed limit at the time of the accident. It does not necessarily mean that someone determined that if the driver had been going slower the accident would not have occurred.tomjasz said:A shame you can't accept facts.slacker said:do not waste time arguing with chalo, he is the poster boy for abortion. His parents must be proud.
"Past NSC research has indicated that alcohol, speed and distracted driving are the three major causes of fatalities on the road, contributing to 30.8, 30 and 26 percent of motor-vehicle deaths respectively."
So booze only leads speed by 0.8 percentage points. Fact before attacks, please.
LewTwo said:It is a problem of bandwidth. More people means less roadway per individual. Same problem on the the internet. Now what the internet has shown us is that faster traffic is the solution. Drive twice as fast and you can get off the road in half the time. Drive four times as fast and ...
Ykick said:Surely the last dozen or so posts will help OP decide which drive system to adopt....???)
Chalo said:Ykick said:Surely the last dozen or so posts will help OP decide which drive system to adopt....???)
Izits only has the one topic. So you'll see it pop up in almost any discussion.
markz said:Mid Drive Options
Bafang BBS02/BBHD
*Cyclone basically the same as GNG
Cyclone 1500W
Cyclone 3kw - This is the one I am buying I think! Gotta carry 375lb rider, plus 30Ah battery 18650 1.6Ah cans. Hills!
Cyclone 4kw - Too powerful for bicycles
Cyclone 7.5kw - Too powerful for bicycles
Lightning Rods
AFT
EGO
ECO
MXUS
Might be more RC choices too
zackclark70 said:there is a few other options but those are mostly way over powered or way under powered ( legal ) once you get to the 75kg bike + rider might aswell convert a 125cc and go 11.5kw and have all the power you need or like me build a 30/60kw with plans to go to 60/120kw
markz said:zackclark70 said:there is a few other options but those are mostly way over powered or way under powered ( legal ) once you get to the 75kg bike + rider might aswell convert a 125cc and go 11.5kw and have all the power you need or like me build a 30/60kw with plans to go to 60/120kw
1.5kw is fine for a bicycle, 3kw is good too. You cant ride a cc anything in a park, on a pathway, take it on a train, on a bus, ride it on a sidewalk, walk it through a mall, ride it off the road in a National Park, cant wizz by people on a trail. I will go with the 3kw Cyclone, I wont use all that power because it will eat away the bicycles drive train. But when I hit a hill, thats when the power is needed with gear changes in preparation for the climb.
huffinandpuffin said:I installed a 350W hub drive with 36V,.... It seems to hit it's maximum capacity on any grade over 5%.
I'm considering the purchase of a Gepida Thoris tandem with Bosch Performance drive,... I assume we'll see better performance and battery life from the Bosch system. Any input? Thanks!
DRMousseau said:huffinandpuffin said:I installed a 350W hub drive with 36V,.... It seems to hit it's maximum capacity on any grade over 5%.
Those grades can really eat it up,... you say "it's max capacity", and I'm thinkin' "yup,.. it probably jus don't do NOTHIN' for 'em on such grade!"
And while doing nothing for ya, it probably jus chews up the battery range 'till it overheats in jus a minute or two and quits completely! UGH!
