I installed a front hub motor, connected the three faze wires, the hall sensor wires and the throttle when I hooked up the battery it ran in reverse
I fitted it as per instructions from the website, its a PaPa motor, I did nothing wrong. Does a hub motor run just as well in either direction? would reversing the three faze wires then run it forward? or is it better to turn the wheel around in the forks which is more of a hassle as I have fitted two torque arms. Thanks
