hillzofvalp
Soooooo close!
hillzofvalp said:Soooooo close!
hillzofvalp said:Just waiting on swingarm and got to mount my controllers/balance wheel and I should be doing 70mph (sans license plate or permit).
hydro-one said:what about the solar panels?? getting sunny here![]()
hydro-one said:Hi John, can you provide some more specs on the panels, (hint start a sales thread) Even just to collect the info, scattered all over......Im interested in a 4s module for sure. However living beside a hydro dam (think terawatts), its not first on my list.....
grindz145 said:John, if you have a solution for a 16-17" rim I'm be really interested. There are a bunch of reasons why a 12" wheel just won't work for me
grindz145 said:Thanks for the info John. I'm looking to build a top-tank moped. I'm OK with modifying, but I don't want to completely screw up the suspension geometry etc. SOunds like this thing would be a bit too brutal at 80V in a 17" wheel.
hillzofvalp said:my bike is in the same class of what he's talking about.. maybe a magnum is a little bit lighter, shorter, and lower. a 9C would be fine in one of those if you didn't exceed 1.7kW probably. You may want to check what the width of the swingarm is.. most peds are horizontal but are closed... which is one reason I made a new swingarm.
I actually was first looking for a magnum for my project.. lol
hillzofvalp said:I think you will be fine with <10kW with original swingarms... IF you can fit the motor in properly. THe hubmonster HE is 190mm ish.. and you need the slot to match the flats or it will just spin. My mb5 original swingarm I think was around 190 but the slots would've never worked unless I welded on hunks of steel and hacked it apart (which I was going to do). Safer to start fresh.
what kind of range/top speed do you want?
