hillzofvalp said:
I just wanted to remind those of you who balance up to 14S: 15-pin D-sub connectors rated at 5A work great. Just be sure to put the male end on the pack so as to prevent shorts.
Would this include "radioshack" generic pins?
I want to share my
tale of stupidity here.
I received the charging harness kit, but, there's a bit of a difference between mine and the pictured ones and directions. The ValULok connector is not a right angle connector, but, instead is flat. This made referencing the pictures and such quickly rather difficult. Well, somewhere along the way what I must have done is installed the connector upside down. The PCB is completely rectangular, so it wasn't as though the orientation of the thing would make it obvious that there was a problem. I assembled the whole thing with some minor difficulties on the pins. It's at this point that I want to point out again what we all know - always use the right tool for the right job. I do not have a crimper for these (I have the 'DB' style) and I do not have an insertion/removal tool. Both of these would have been invaluable.
Failing to properly crimp the pins meant I used the ol' jewler's screwdriver to insert them. But, this wasn't in itself terrible, it just resulted in a less than proper insertion.
So... I figure, hey, looks good, diagram seems to line up . I had already shrunk and wrapped the PCB side, so, again, in my hurry, I failed to notice it wasn't lining up right. I attached the cable to the charger, turned it on, attached the LVC board. Grabbed a pack, and went to plug it in. It took about a second before there was a sizzling and a burning smell, and I ripped it off. The trace out from the #2 balance lead had burned up.
I don't know what sort of current that was pulling, but, what I now know had happened was that the #1 and #2 balance lead pins shorted through the cable. Fortunately, it was that which burned up, and the pack appears undamaged. Of course, hearing enough stories about this, I fully expect it to explode in my face overnight. It is living in the oven in a LiPo bag, although, given the terrible quality of this apartment, the metal in the oven is probably flammable. I'll check on it before I go to bed for any puffing, but, it doesn't appear there is a problem. I'm not sure what the current capacity of the PCB trace is. I'm going to guess it's fairly low.
SO. Now that I've identified my major screw-up, I started to pop out the "pins" until I realized that I had just crushed and ruined several of them. I do not believe this will be salvagable, I think there were four extra pins. Maybe if I'm careful I can pull it off, but, I need the removal tool, and I don't know if the "DB" tool will work.
So, this all is rather lame. I repaired the trace on the LVC with some solder, lacking a conductive pen. I know that board works, well, it worked before, and I estimate it should be fine. Of note, using the wire leads that come with the charger leave you without anything to charge your batteries with until you replace that cable. I will grab some banana connectors and make up a banana/APP cable tomorrow so I can charge individually anyways.
I figure given the number of newer posters querying about LiPo recently, someone else may make this same error , but, with a worse turnout, so, be careful!
I will update if my apartment burns down I guess
