chelsealuttrall
- Joined
- Jan 31, 2021
- Messages
- 15
Hi, I am converting my moto and I have this Kelly Motor (https://kellycontroller.com/shop/kls-8080h/). Every thing works fine when I'm performing the "angle operation" and I have that wiring set up. But when I switch the wiring back to the normal wiring diagram the following happens.
My on switch is working when I turn it, I hear the TYCO contactor click. However, nothing is on at the level of the controller (7). It seems there is no draw from the controller (I'm guessing a fail-safe for excessive voltage? or something of the sort? But I don't know what the voltage should be besides the 76 volts I have coming from the battery as indicated by the wiring diagram). What does the controller want at port (7)? Or is it something else? When I check my voltage at each point, the voltage is 76v on the coil + side, but on the other side, it's dead. I do have the diode installed. Ideas?
Disclosure: I'm learning as I go so if you think it would be obvious or dumb to tell me something to check, it wouldn't be. Say it all. I'm a DIYer with no previous experience.
