astmacca said:
Wow, you are not making this an easy one are you??
I reckon if you mount anything like mine under that main tube it will interfere with the front wheel.
No, I'm not
It's a bit of a large project , to build an optimal MTB bike with a kit (and not ready slick design like Haibike), and you guys helping me a lot, 'cos when I read your suggestions and think of it, the final picture becomes a little bit clearer.
And even if I don't except those suggestions, it means I found another little bit of a puzzle, which you helped me with. There are a lot of aspects, not just electrical, that I become aware as we continue into this jungle more.
Interfering with the front wheel is definitely a concern, especially on small-sized frames (and this one is definitely small).
astmacca said:
I have seen some pics of bikes with the batteries mounted on top of the top tube but looking at those pick always makes me uncomfortable for some strange reason??
Top of the tube won't work for MTB - the battery will be constantly hit with knees while pedalling... Unless it's really in the front, but then it may interfere with the handlebar and put too much weight on the front, which will make the front heavier and as a result climbing rock stairs more dangerous...
astmacca said:
What about a beam type rear carrier?? Like:
http://www.torpedo7.com.au/products/DACRSNNMP/title/delta-megarack-post-haste
Which has a limit of 20lbs / 9kg and is 110mm wide and 375mm long in the platform.
On Pauls site:
http://em3ev.com/store/index.php?route=product/product&path=35&product_id=128
The 14 aH rectangle pack battery weighs 3.7kg and is 138mm by 203mm wide. You'd need to build a simple box to protect it but i'd be surprised if you couldn't get it mounted that way for less than 5kg for the battery and box plus 0.52kg for the carrier. That's well within the weight limit for the carrier and i am sure that there are other people on here who would be able to tell you of a carrier like that would give you problems off road??
Beam type also won't work - too much weight on the rear, the rack can fall of or bend, or ruin the dropper seatpost.
I.e. has to be downtube..
After re-reading this, it seems that I sound too negative, but I'm actually not, I'm very thankful for any suggestion
